View Poll Results: how do i know for sure with out just replacing random parts
time it takes
100.00%
is it a good idea fir DIY on this
100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
04 ranger 3.0 misfiring
Old Nov 25, 2022 | 12:07 AM
KHODY's Avatar
Default 04 ranger 3.0 misfiring
my cylinder 6 is firing at 40 psi i changed the spark plugs coils and wires I plan to check injectors next where should i go after that and is it worth $90 per hour to have some one come through the engine I work on tires for a living so i know my way around nuts and bolts. I just want a second opinion and if my truck has 295000 miles should i just plan on replacing the engine
Old Nov 25, 2022 | 06:14 AM
Only you know how well your truck was maintained.
It has some miles on it, but I wouldn't throw in the towel yet.
A compression test would give some idea of the engine condition and you could make a better judgement after you know the condition of the inside of the engine.
A lot will depend on what is found there. If the test shows some life still left in the engine and is pretty even, you might look for another cause.
theunpaidBill
Sep 6, 2013 03:27 PM
RandSand
Sep 28, 2009 03:46 PM
ohno5o
Sep 14, 2006 09:37 PM
RangerGuy25
Apr 4, 2006 04:53 PM
RangerGuy25
Apr 4, 2006 10:33 AM
