1988 2.9 2WD tranny removal
Old Aug 21, 2006 | 03:53 PM
scoob8000's Avatar
Default 1988 2.9 2WD tranny removal
How hard is it to remove the transmission from this truck? Does the exhaust have to come down?
My input shaft bearing is shot, and I'm being quoted over 250 just for labor to remove and reinstall
the tranny.
I found a completely rebuilt unit for $750, and I'll do that if I can do the labor myself.. That exhaust looks like it'll be a PITA to remove, but it almost looks like the bellhousing will clear it.. Anyone know for sure?
If I can't do it myself, I can't justify putting that much money into this old of a truck..
Old Aug 24, 2006 | 07:29 PM
94 4x4 ranger's Avatar
Default RE: 1988 2.9 2WD tranny removal
If you think you might be able to handle it I would get a manual from the auto part's store.
Old Sep 9, 2006 | 12:45 AM
floyd's Avatar
there is a flange lip around the doghouse which interferes with this job. if you do the job, beat that flage lip flat against the body before you reassemble. it gives you the clearance needed. also if you replace the clutch DO NOT reface the flywheel! use only NEW OEM parts including throwout bearing. it sounds to me like a fair price to have it done and i've done this job myself before. pay the man and work an extra shift of overtime at work!
WB4IUY
Oct 9, 2014 06:06 AM
surferbum
Oct 3, 2011 04:48 PM
bill9iron
Dec 2, 2007 02:14 PM
halfast1227
Sep 8, 2006 12:57 PM
nicholsmf
Oct 29, 2005 08:03 PM
