1996 ranger 3.0 valve problems
Old Jan 31, 2010 | 08:11 PM
1mobile's Avatar
Unhappy 1996 ranger 3.0 valve problems
Just put on new head gaskets....now have 0 compression on all cyls. What did I do wrong the valves seem to be open? HELP!
Old Jan 31, 2010 | 08:19 PM
mgar75's Avatar
Maybe you put the wrong head gaskets on the wrong side were they marked with L & R there might be a differance.
Old Jan 31, 2010 | 08:31 PM
1mobile's Avatar
Same gaskets both sides... can back rocker bolt off and get comp.
Old Jan 31, 2010 | 08:56 PM
ralphie250's Avatar
why did you repalce the head gaskets??
Old Jan 31, 2010 | 09:06 PM
1mobile's Avatar
blown
Old Feb 1, 2010 | 07:22 PM
mgar75's Avatar
Sounds like your timming is off . Because if you back off the adjustment screw on the rocker and you get compression means your head gasket is on right . You must have your timming wrong if it is off you will not get any compression because your valves will open at the wrong time.
spatterfree
May 20, 2015 09:59 PM
jenmes70
Jul 29, 2013 07:17 PM
rangerman95
Dec 24, 2009 12:34 PM
ramrod
Oct 27, 2009 07:30 PM
kwikane7
Sep 12, 2007 06:29 AM
