2000 4x2 Speedo not working
Old Apr 5, 2006 | 08:46 PM
2V's Avatar
2V
Default 2000 4x2 Speedo not working
Hello, I recently bought a 2000 Ford Ranger, 4x2. Nice truck but the speedometer and Odometer do not work. I have replaced the ABS sensor an the rear axel as the ABS light is on with no luck. I replaced the speedo cluster today with a used one with the same results, still does not work.
Is there a speed sensor somewhere or does anyone have a suggestion? My local Ford Dealer assured me it was the speed cluster and wanted $500 for a new one. I installed the used one myself but it was not it.
Thanks
Old Apr 5, 2006 | 09:20 PM
CoyoteRoede's Avatar
Default RE: 2000 4x2 Speedo not working
check the fuse or maybe u just got a ****ty replacement cluster.
good luck
Old Apr 5, 2006 | 10:44 PM
2V's Avatar
2V
Fuses are OK, its possible the cluster is bad as well but the seller asured me it was working, I guess I'm looking for feedback from others with simular problems.
Old May 19, 2006 | 05:14 PM
cctxfish's Avatar
You need somebody who can use a scantool and check vehicle speed at ECM. If it is giving the incorrect info it maybe the speed sensor at transmission, harness, connector, or even ECM. good luck
Old May 19, 2006 | 09:30 PM
drw0392's Avatar
I had a similar problem. Suddenly my speedo stoped working out of no where. I looked under the truck at the tranny and discovered that the speedo cable had come loose. I tightend it and the speedometer worked fine. If you look and the cable is tight, pull it out anyways to make sure the little gear on the end isn't stripped. Good luck, and let me know if that helped.
bobsylv
Apr 10, 2012 08:02 PM
RevKev
Mar 14, 2011 05:48 PM
fairmonster
Mar 4, 2010 10:40 AM
bronco2
Sep 22, 2006 08:22 AM
bronco2
Sep 16, 2006 06:57 AM
