2000 Ranger 4.0l fuel issue.
Old Aug 28, 2017 | 03:02 PM
VernonH's Avatar
Default 2000 Ranger 4.0l fuel issue.
I have a 2000 Ranger with a 4.0. My fuel pressure is at 72psi at an idle. 70psi running down the road. I believe it should be around 65psi. My truck also seems to be running very rich. Rather bad mpg and you can smell gas while it runs. It will also load up and stall if you sit at a light/stop foe an extended time. Haven't had a chance to put a scanner on it yet.
Old Sep 1, 2017 | 08:44 PM
There should be a fuel pressure regulator on the injector fuel rail with a vacuum hose connected to the top. If you remove that small hose and fuel comes out or has any fuel in it, the diaphram in it is ruptured and it needs to be replaced, not a difficult job.
Old Sep 1, 2017 | 09:34 PM
VernonH's Avatar
I will check it out. Thank you.
fordexpedition2006
Apr 21, 2017 05:23 PM
2004freestarmatt
Feb 8, 2009 06:39 PM
Mikeraqhed
Nov 14, 2008 04:31 PM
bazuka
Jan 9, 2008 03:08 PM
messierfan
Apr 4, 2007 02:01 AM
