95 ranger possible fuel issue
Old Apr 2, 2007 | 01:29 PM
messierfan's Avatar
Default 95 ranger possible fuel issue
I have a 95 ranger, just got it a while agoe and usually runs like a charm. Problem is it sarts perfectly on a cold start, but as soon as its up to operating temp, I have a hard time starting it again if its shut off for a while, It will eventually sputter and start if i give it gas when it sputters. I was thinking maybe it might be the fuel shut off but not sure at all.. I was wondering if anybody else had any ideas or have went thru this with their rangers.
Thanks in advance
Old Apr 2, 2007 | 08:15 PM
goinstrong's Avatar
Default RE: 95 ranger possible fuel issue
How many miles are on it? Have the catalytic converters ever been changed/serviced?
Old Apr 2, 2007 | 08:16 PM
goinstrong's Avatar
Could be a bad wire or dirty battery cables too.
Old Apr 2, 2007 | 09:52 PM
wheelsup68's Avatar
Clean the throttle body! You may not be passing enough air to get the hot start you need. It is definitely not your fuel cutoff.
Old Apr 4, 2007 | 02:01 AM
goinstrong's Avatar
Dirt in a clogged converter can expand when hot enough to shut down exhaust flow, also. I agree - very doubtful on the fuel cutoff - it would totally shut you down and never start until reset unless it was a really weirdly failing switch.
fordexpedition2006
Apr 21, 2017 05:23 PM
soraxcloud
Apr 29, 2014 09:55 PM
Jdubu420
Sep 3, 2013 05:55 AM
zakkglass13
Jul 6, 2013 03:18 PM
zaroslinski
Jul 13, 2009 05:23 PM
