88 ranger
Old Jun 24, 2012 | 02:36 PM
fred12564's Avatar
Default 88 ranger
My 88 Fored Ranger will go about 2 miles and then it will shuts off.
Replaces:
Distributor
both fuel pumps
Old Jun 24, 2012 | 05:45 PM
What about the fuel pump relay?
Old Jun 26, 2012 | 02:42 AM
Use Common Sense's Avatar
Check to ensure that the small ground lead coming off of the negative battery post has a good clean connection. This is the main ground to the CPU along with other components and loss of, or a bad connection of this ground will keep the fuel injectors from firing.
Old Sep 3, 2012 | 08:43 AM
bandit1948's Avatar
it might be that the coil is getting too hot and shutting the engine down !
