90' Ranger troubles
Old Oct 22, 2012 | 06:12 PM
Jesse Hillbilly Gensheimer's Avatar
Default 90' Ranger troubles
Im about to buy my buddies 2.9L 1990 ranger 4x4. reg cab. I have multiple questions, i like to go offroad, how high do i need to lift it so i can fit 31s under it. next. i test drove the truck, and its slow as dog ****, its acceleration is preety slow. Im not sure if this is because there is no exhaust(just manifold)so no catalytic convertor and O2 sensors. or what. but i would like to make it a little quicker in the acceleration. Its $500 and its a good beater truck but id like to do some work to it. so 2 questions. How high do i need to lift it to put 31s under it(also where can i find some CHEAP blocks to lift it). and It has slow acceleration, how can i fix that?
Old Oct 25, 2012 | 11:31 AM
Use Common Sense's Avatar
As far as tires...Shouldn't need to lift it to put 31's under it unless the suspension is sagged. Being a 1990, it probably has 15" rims if stock unless they were changed out. I ran COOPER's Discover S/T (31x10.50R15LT's) with no issues on my stock 1988 Ranger XLT S/C 4X4.
How many miles are on this 22-23 year old truck?
Being a 2.9L V-6, it only has like 145HP if you're lucky due to its age.
Speed? What gears are you running? The 2.9 isn't a speed demon.
Also, the 2.9L loves back-pressure. It just doesn't have any type of performance without it.
Old Oct 25, 2012 | 08:04 PM
really? you could fit 31s? thats preety good. i didnt know theyd fit. figured they would rip. also it has 155k miles on it. stock gearing. decided to throw on dual straight pipes with a mufflers to give it back pressure since i dont wanna buy new cats. only thing it NEEDS is exhaust system and valve cover gaskets, which the 2.9s are known for going threw those. but i have another question, does it NEED valve cover gaskets, i plan on putting them on eventually but does it need them? since their blown it just burns threw oil so i dont believe its much trouble
Old Oct 25, 2012 | 08:07 PM
rub* not rip
Old Oct 26, 2012 | 06:16 AM
Being a 1990, I'm not 100% positive. Mine was a 1988, which was the last year of the original body style.
Stock tires for both were P215/75R15 or optional 225/75R15 & 235/75R15. A 31x10.50-15 is about 2" taller, which will only be 1" taller in the wheel well. The section width is about 1.5" wider, which will set the tire about 3/4" farther in towards the suspension.
Easiest thing to do is take measurments with the tires straight, then rack the tires hard right and left, then measure the clearances.
Dec 10, 2012 03:26 AM
BRhodes
Jun 2, 2008 07:00 PM
Eli Delta
Jul 8, 2007 01:09 PM
deedee3371
Jul 23, 2005 12:53 PM
Hiram
May 13, 2005 03:53 AM
