97 Ranger
Old Apr 7, 2022 | 01:35 PM
popperstopper22's Avatar
Default 97 Ranger
I have a 97 ranger 3.0 automatic, having issues with rough idling skipping and jerking , when first crank up truck has a rough idle but then it leavels out , then going down the road does fine until it hits overdrive then it starts skipping and jearking , sometimes it does it then other times it don’t, i notice if it sits for several days before i drive it its worst , i have cleaned mass air flow sensor , installed plugs and wires , if fact when i replaced the plugs and wires it ran fine for about a week then started back doing the same thing , it only does it in overdrive trying to get up to speed , once i get to the speed and don’t have to push the gas it stops but time i give it gas it starts back skipping and jerking, any help on what my next step should be please let me know
Old Apr 7, 2022 | 04:11 PM
raski's Avatar
Make sure its not a misfire under load. Check for codes and fuel pressure.I once had a plugged fuel filter do the exact same thing. If the engine checks good, you may have a torque converter issue.
Old Apr 7, 2022 | 04:24 PM
would that be the fuel filter under the driver side under the seat mounted to the frame ?
Old Apr 7, 2022 | 11:24 PM
raski's Avatar
yes it is.
icedog
Jan 21, 2008 07:04 PM
soulchick_27
May 30, 2007 08:36 AM
bumble78
Apr 26, 2006 03:34 PM
neillitke
Apr 3, 2006 04:36 PM
ROBERT47846
Feb 13, 2006 03:22 PM
