clutch bleed problems with 94 Ranger
Old Sep 5, 2006 | 05:42 PM
  #11
94 4x4 ranger's Avatar
Default RE: clutch bleed problems with 94 Ranger
If you clutch fluid resivior was empty you may very well have a leak.If you do even the slightest leak it will never bleed right.I would look for seapage in back of the master,lines and the slave.If the slave is in the bell housing it would have seepage at the bottom if it is leaking.
Old Sep 7, 2006 | 11:18 AM
  #12
ryanjantz's Avatar
just an update if it may help anyone else out. Ford suggests taking the master cylinder off to bleed since it is tilted downward. I unbolted it and disconnected the clutch rod so i could tilt the MC upward and air that was trapped could flow up to the clutch line. Automatically gravity brought the air right up out of the resevoir. i had to do that two different times but it runs great now!
Old Sep 8, 2006 | 12:17 AM
  #13
Mulletman's Avatar
Glad you got it worked out!
pmmayo
Jan 18, 2015 01:52 PM
dave boley
Oct 29, 2012 11:45 AM
keith G
Jan 16, 2012 01:44 PM
MercuryMountaineer02
Jul 7, 2011 08:45 PM
brian_ensminger
Apr 10, 2011 09:08 PM
