clutch slipping
Old Aug 29, 2006 | 04:08 AM
a54hillbilly's Avatar
Default clutch slipping
I have a 89 ranger 4 speed/OD with 282,000 plus miles. It has the original clutch in it. It started slipping and I checked the fluid level and it was empty. Could this be the reason it is slipping or will I have to replace the clutch?
Old Aug 29, 2006 | 10:15 AM
94 4x4 ranger's Avatar
Default RE: clutch slipping
[sm=welcomesign.gif]First you will have to find the leak then replace the part. You may get lucky.But having that many miles on it it may be time.
Old Aug 29, 2006 | 01:29 PM
techmanbd's Avatar
Damn, that is alot of miles on the original clutch. It is probably do to be replaced. The 93 I had was close to 150,000 miles and started slipping. But that was also driving in Los Angeles traffic alot.
Old Aug 29, 2006 | 02:10 PM
Would it be worth trying to just add fluid first instead of replacing the cluth?
Old Aug 29, 2006 | 02:27 PM
You will have to add fluid to see where the leak is coming from first . But wont make the problem go away.
Old Dec 8, 2006 | 01:15 AM
Frankenstein Ford's Avatar
At 100,000 LESS than yours I had to change the original clutch on my '89 and I took out the TEENIEST clutch disc I think I ever saw on something with four wheels. I replaced it with one almost twice it's size.
If yours is the same size I find it truly amazing to make almost 300,000
To avoid dealing with the hydraulic line which I still am not sure how it comes apart, and I kept reading a lot on these forums of people having a world of trouble after messing with them, I just took the whole engine out instead. It sounds like you might have to deal with yours. Good luck
texashobo
Dec 12, 2014 05:10 PM
makuloco2000
Jul 22, 2014 08:33 PM
jmelees
May 17, 2012 02:38 PM
cyberrkatz
Jul 7, 2010 09:46 PM
skid2964
Sep 27, 2009 02:29 PM
