Fuel Filter-change
Old Oct 14, 2008 | 04:05 PM
ERG_90_Ranger's Avatar
Default Fuel Filter-change
I've read posts on peoples’ biggest problem were getting off the filter. However, my biggest problem was that I don't want fuel spilling to occur. In the Chilton manual it explains to take the gas tank cap off and disconnect the vacuum hose from the pressure regulator, then take a hand vacuum pump and apply pressure to the pressure regulator. Keep truck tilted so engine is at same level if not higher than rear to keep from fuel siphoning occurring. Is that really everything you must do? Can't I just press the button on the inertia switch and crank the engine until it runs out of fuel and dies?
Old Oct 14, 2008 | 11:03 PM
Use Common Sense's Avatar
Default RE: Fuel Filter-change
The button on the inertia switch just resets the switch in the event that it trips. Just unplug one of the leads to the inertia switch and start the motor. Let it run to a stall. At this point, the only fuel that will come out when the filter is changed is the fuel in the filter and line but it won't be very much and not under pressure.
cervin
Aug 14, 2007 11:21 AM
cwood08
Jul 20, 2007 02:01 AM
arneeche
May 11, 2007 06:12 PM
dee004
May 8, 2007 08:04 PM
fobagbob
Jan 18, 2006 03:20 PM
