FUEL PROBLEM
Old Apr 23, 2008 | 04:54 PM
CJG86's Avatar
Default FUEL PROBLEM
I HAVE AN 1986 FORD RANGER2.3 F/I ENGINE JUST REBUILT
BEFORE AND AFTER THE REBUILD. I WILL BE DRIVING DOWN THE ROAD AND THE ENGINE WILL LOOSE POWER AND START BLOWING BLACK EXCUST OUT THE TAIL PIPE AFTER A MIN. OR SO IT WILL STOP AND DRIVE JUST FINE. SEEMS TO DO THE SAME AFTER DRIVING AND SHUTING ENGINE OFF AND RESTARTING
Old Apr 24, 2008 | 04:08 AM
Use Common Sense's Avatar
Default RE: FUEL PROBLEM
Check for a bad O2 sensor. I had the same issue with my 88 Ranger with the 2.9 in it. Be driving along and then less power, look out the side mirror and see black smoke coming from the tail pipe. Always came and went as it pleased with no common occurance. Replaced the O2 sensor and all was fine since. It never set a code.
Old Apr 24, 2008 | 09:45 AM
CJG86's Avatar
Thank you for the idea I will be replacing the O2 sensor asap will let all know results
thanks again
Old Apr 25, 2008 | 09:19 PM
oldtimer35's Avatar
The O2 sensor does not cause an overfueling problem, it just tells you about it. I would think you either have a problem with the fuel pressure regulator or the injectors. This is not just a plug in part repair. It needs to be diagnoised by watching fuel pressure when the problem occurs to see if it increases at that time. If not, then maybe the injectors need to be cleaned.
Old Apr 26, 2008 | 09:54 PM
An O2 sensor can cause an over fueling problem by telling the computer that it is seeing too much o2 in the exhaust. Too much o2 is a LEAN condition to the computer. The computer then compensates for this by increasing the length of the injector pulse to try and maintain a 14.7:1 air/fuel ratio. Thus a rich mixture and black smoke.
Old May 30, 2008 | 03:31 PM
CJG86's Avatar
I am happy to announce that theO2 sensor was the problem. Not only has the black smoke totally gone away
but my fuel mielage has almost doubled I did have the fuel pressure checked out and it was good.But stoped short of pulling injectors. (money concerns) thanks for all of the input
Old May 30, 2008 | 11:36 PM
Glad to hear your problem is resolved. Thumbs up to you for responding back as to what the outcome was. A lot of times one never knows if their suggestions actually helped to resolve an issue.
Greasy Creek
Jun 12, 2012 02:47 PM
stargate_div
Sep 11, 2008 11:12 PM
grumpydave
Jan 18, 2008 03:15 PM
kewiegand
Oct 27, 2007 07:17 PM
gwald
Mar 26, 2006 01:09 AM
