Limited slip rear?
Old Sep 26, 2005 | 10:03 PM
FM544's Avatar
Default Limited slip rear?
Hi, new to the Ranger scene with a '98 , 3.0, auto, 2 wheel drive that I just bought. I love the truck and was thinking of some improvements such as for the winter would it be worth it to change the rear end to a limited slip rear? I don't know what ratio I have back there now but thought about if I did make a change to put in a more economical set of gears. Can I use the housing I have now and just change the internals or do I need a whole new set-up? Any advice would be appreciated. Frank
Old Sep 26, 2005 | 10:50 PM
rusty ol ranger's Avatar
Default RE: Limited slip rear?
Trac Lok helps alot in the snow.
So does cinder blocks.....in my 87 2wd I use 5 concrete blocks all the way in the back of the bed, that and enough right foot with decent tires I can pass 4x4's.
You dont wanna gear a 3.0L and higher then comes factory. 3.0's are gutless in torque and igh gears zap what little they have.
later,
Dustin
Old Sep 26, 2005 | 11:09 PM
FM544's Avatar
Thanks, I assume by Trac-loc you mean the limited slip rear? Do you know if it's a big job to install? I will probably go the cinder block route and snow tires for this winter and see how it goes. Thanks for the advice.
Old Sep 28, 2005 | 12:05 AM
Your better off going to the junkyard and pulling a axle already equipped with limited slip (Trac Lok).
later,
Dustin
Old Sep 28, 2005 | 06:05 PM
FM544's Avatar
Gotcha, Thanks
Frank
skid2964
Feb 19, 2015 09:57 PM
clarion12s
Dec 3, 2007 09:43 PM
Cinnabon
May 8, 2007 07:35 PM
ZeidersR
Nov 1, 2006 11:36 PM
RNGMSTR
Jul 14, 2006 11:17 PM
