noisy front end
Old Jan 1, 2020 | 11:23 PM
gwoker's Avatar
Default noisy front end
I have a squeaking noise coming from the front end on my 2005 Ford Ranger Edge and it seems to be located at the steering shaft box. Is there a history of this with the Rangers and what is the general solution for fixing?
Old Jan 2, 2020 | 03:47 AM
Sometimes the U-joint at the bottom of the steering shaft gets dry and a little lubricant at the crosses gets rid of the squeak.
Old Jan 2, 2020 | 05:33 AM
raski's Avatar
Sounds like the common ball joint(s) going dry and start screeching till they eventually give out.
Old Jun 26, 2021 | 05:29 AM
Akbar Adeli's Avatar
Hi folks,
Loose or worn belts are a common cause of vehicle squealing. An old or failing alternator can make squealing sounds. If your car squeaks or squeals while turning the steering wheel, it's probably the steering system. Brakes squealing is their friendly way of telling you it's time to get them serviced.
Old Jun 27, 2021 | 07:13 AM
raski's Avatar
Originally Posted by Akbar Adeli
Hi folks,
Fords are notorious for ball joints going dry and squeeking. I think most can tell the difference between a belt squeel and a squeeky front end.
fireman1296
Sep 17, 2014 04:01 PM
cappo
Mar 21, 2012 07:45 AM
61 2DOR
Aug 9, 2011 07:30 PM
billj818
Jul 30, 2007 08:41 PM
gminfla
Jun 7, 2006 12:07 PM
