Performance problem
Old Sep 3, 2005 | 10:55 AM
wvxr7cougar's Avatar
Default Performance problem
I noticed the 93 I just bought didn't seem to have as much power as the 89 I just sold. They were both 2wd, 2.3L, 5 sp trucks but hills I can climb in 4th gear in the 89 I have to use 3rd in the 93. After driving the 93 for a few days I have noticed what seems like a minor miss. espcially noticable under load or cruising in 5th gear at highway speed. Seems kinda odd, not like a hard miss. The check engine light isn't on and the plugs and wires look fairly new although I really don't know the history of the truck. I am thinking it could be a coil problem or fuel pump? any suggestions?
John
Old Sep 18, 2005 | 09:53 PM
big red's Avatar
Default RE: Performance problem
Sounds like your timing's off.
Old Sep 19, 2005 | 01:40 AM
I have tested the fuel pressure and replaced the plugs even though they looked new with no change. The check engine light doesn't come on so there are no codes. I pulled a wire off a sensor so it would kick the light on and go into bypass and it runs normal but I have to look at the check engine light...frustrating. I thought it was one of the coil packs but the miss went away when I unplugged the sensor.
coolt2190
Nov 4, 2008 02:44 AM
3.0_liter_02
Jan 20, 2006 12:02 PM
superdookie1
Apr 7, 2005 02:42 PM
FordZX2
Sep 4, 2004 10:30 PM
new era performance
Jul 14, 2004 07:00 PM
