Questions about ignition system.
Old Nov 7, 2019 | 06:30 AM
JCS's Avatar
JCS
Default Questions about ignition system.
I am putting a 2.3 liter Turbo in a project pickup. I am not familiar with this engine and it's systems so maybe someone can teach me a few things.
Regarding the ignition system; The turbo engine I have is a 1985 4 cylinder out of a T-bird but I understand this 2.3 was a standard for Rangers for a long time. It has a distributor without points and I understand that but I have no other ignition parts.
What else do I need to build my ignition system? I am sure there is a coil of some type and I have also read about using a coil pack. Does this eliminate the distributor?
How clean can I make this system in terms of simplicity? Do I need the T-bird or Ranger fuse panel because it has relays etc I may need? I have done some innovating with builds where I used later engines without a distributor, only a coil system, an igniter and the ECU.
This is going into a 1929 Ford pickup (an old Ranger I guess).
Thanks for any help you good folks can offer. Jon
Fordster3038
Dec 21, 2013 03:57 PM
Scott Beam
Jan 14, 2011 11:22 AM
dmack
Jul 8, 2009 04:21 PM
Snazzman
Feb 2, 2009 10:44 PM
nissta90
Apr 17, 2008 07:22 PM
