Trunk wont turn over after new coil, wire, plugs
Old 11-29-2017, 01:45 PM
trisporter717's Avatar
Default Trunk wont turn over after new coil, wire, plugs
Have a 2000 Ranger with 4.0. It was running rough and we suspected possible MAF issues after using SeaFoam but have already replaced the MAF with a new one. So started trouble shooting with diagnostic computer, etc.Had two bad plugs and wires. Replaced the ignition coil, wires and all the plugs just to insure that the end to end was covered. Checked it with the computer and get zero codes. But the Ranger will not turn over at all. It will occasionally cough and sputter but will not fully start. I started reverse diagnosing by putting the old ignition coil on with the same result of not starting. I do not see how replacing the 6 plug wires and plugs would cause this issue. Looking for answers from the crowd. Thanks
Old 11-29-2017, 04:18 PM
Did you replace the plug wires one at a time or did you remove them all and then start to reconnect them?
Old 03-01-2018, 09:28 AM
f250nut's Avatar
My guess is maybe replaced plug wires and crossed them up a.k.a. wrong firing order.
Old 03-01-2018, 11:35 AM
Since we have't heard from him back in Nov of last year, we can be pretty sure he corrected the problem or had someone do it.
Jose Zamora
07-31-2017 01:41 PM
Jon Moore
12-12-2015 03:30 PM
sweetf150
News, Updates and Announcements
07-24-2011 11:40 AM
Crimepuppy
10-27-2009 06:51 AM
Mantis
11-24-2005 01:17 PM
Quick Reply: Trunk wont turn over after new coil, wire, plugs
