2004 sport Trac dot water leak
I saw water leaking under this vehicle when it was running in the driveway. I thought it was maybe the water pump since it seems to be near the front of the engine. I removed the fan to get to the water pump but it isn't leaking. There is coolant on top of the engine. I'm not sure where it could be from other than the thermostat housing. Any ideas what to look for would be a great help. Thanks in advance.
Make sure the coolant level does not get low.
What we do to find coolant leaks, is pressurize the system and look for the leak.. Some places maybe Autozone will come out and do that for you at their store. Then you can buy what you need..
