00 taurus sho start shimmy at 55mph .
Old Jul 30, 2015 | 03:51 PM
teeham's Avatar
Default 00 taurus sho start shimmy at 55mph .
Had new tires all way round it ailment both tie rods replaced March 15 .wind get 55-60 steering start shimmy feel jerking .go back 50 it stops.
Old Jul 31, 2015 | 07:04 AM
primem's Avatar
did the problem start after the tires were replaced?
Canadian tire or walmart brand tires are junk. a brand new set of Canadian tire SE 's shook the steering and dash out of my car at any speed higher that 60mph.
Only way to rule them out is to road force balance them or swap known good tires.
Other possible causes are worn engine mounts or bad cv shaft.
Old Nov 4, 2015 | 05:55 PM
Skyhawk's Avatar
Ball joints, strut rod bushings, inner tie rod ends, front wheel bearings, CV joints, poor tire tread design or bad tires as suggested above, to suggest a few additional possibilities.
Old Nov 5, 2015 | 03:10 PM
Someplace you can start and that is as suggested earlier try switching one rear tire to the front, see if any improvement. If not switch the other rear tire. That would eliminate all four tires as a possibility unless they are all poorly balanced.
Old Nov 6, 2015 | 04:13 AM
Use Common Sense's Avatar
Something else to look at...Lost wheel weight...
I had a 2000 Taurus that I had new sneakers put on all 4 corners. I also has a shimmy start around 65MPH on the thruway, but only when in the left lane. Turned out to be a wheel weight popped off shortly are the tires were installed. Rebalance and reweighted cleared my issue.
BCBEEF
Mar 21, 2008 03:56 AM
crow01
Aug 15, 2007 01:44 PM
sludgemonger
Jan 1, 2007 11:20 PM
sludgemonger
chaud
Apr 27, 2006 12:17 AM
