02 Taurus cranks but won't start
Old Dec 31, 2013 | 04:16 AM
  #11
A test lite is a simple tool where a wire is clamped to a good ground connection and when the pointed probe is touched to any place where power is available , the lite will illuminate. A visual check for power. A voltmeter will do just about the same thing ,but there are certain places where a typical test lite cannot be used like some computer circuits. What we are looking for is power to the coils and hopefully determining whether the computer is getting the correct signals to fire the coils thereby providing spark. Again ,how did you determine you were not getting any spark?
Old Dec 31, 2013 | 02:55 PM
  #12
BillSinclair's Avatar
I inserted a Phillips screwdriver of the appropriate diameter into the plug boot and held it close to a known good ground while some one cranked the engine. I had no spark at any distance.
Old Dec 31, 2013 | 07:40 PM
  #13
That coil pack can fail and shut down the engine which might be what happened with your vehicle. Without the right test equipment the only choice you might have is to replace the coil.
Old Dec 31, 2013 | 08:22 PM
  #14
What are the ways I can test the coilpak(s) can it be done without removing the upper plenum? I notice that mine is hiding up near the firewall behind the plenum.
Old Jan 5, 2014 | 09:53 PM
  #15
I searched on line and found the ohm ratings and procedure for checking the primary and secondary circuits in the coil and mine failed. I also checked my plugs especially the firewall side bank which are nearly impossible to remove without removing the upper plenum. Anyway I replaced the coil-pak and all spark plugs. It STILL will not start.
AAGGHHHHHHHHHH!!!!!!!
now what?
Old Jan 6, 2014 | 11:04 AM
  #16
schroensr's Avatar
I think you may want to look at the crank position sensor located at the passengers side of the car. This is what sends a signal to the coil to fire it when starting.
Old Jan 6, 2014 | 02:45 PM
  #17
Do you have spark now that you replaced the coil pack?
Old Jan 7, 2014 | 09:09 AM
  #18
Schroensr,The crank sensor was replaced already as noted several posts back, thank you anyway however
Hanky, I haven't checked yet. It was cold and raining and late ( I'm working in the driveway ) when I finished with installing the new coil and when it did not start I just put away my tolls and went inside to get dry and warm. On top of having problems with the car, I have been in and out of the hospital and to an array of doctors appointments in the last couple of weeks trying to control an infected foot injury ( I'm diabetic ). This has put a damper on my efforts to work on the car. Today it is 10 degrees with a -7 wind chill index and I haven't worked up the desire to go outside and pop the hood. I'm on the verge of a meltdown right now if something doesn't start going my may here. thank you for your advice so far and I hope you stay with me till I get this thing running. Once I check for spark ( at the plug end of the wires and at the coil towers both, I will post the results. If perchance I still have no spark where should I look next?
Old Jan 7, 2014 | 03:00 PM
  #19
Bill if I may,
No car is worth increasing complications in situations like you are in.
If possible wait it out until the weather gets more cooperative.
There are a few different paths this thing with the car can go. Once the weather permits disconnect the negative cable from the battery and hold it on the vehicle's positive cable at the battery for at least 5 minutes to allow the keep alive memory to be erased, then reconnect it. Before doing anything else check for spark. We'll be in the area to help and if not soon enough there are other folks on this forum that will help also, it's a good forum and we usually work together. Stay warm and feel better !!
Old Jan 9, 2014 | 01:08 PM
  #20
OK, I checked for spark at the plug end and at the coil and there is nothing. I crossed the battery cables as noted and tried again and still nothing.
HELP!!!!!
