2003 Taurus theft Light flashing and wont start
Old Sep 26, 2015 | 05:15 PM
2003sable6767's Avatar
Default 2003 Taurus theft Light flashing and wont start
I just picked up a 2003 Ford Taurus With 67k miles on it for $300, But the theft light is flashing and it will not start? The engine will crank and sound as if it wants to start but it wont. The radio also works on it. What could be the problem?
Old Sep 26, 2015 | 06:17 PM
Did you get the 2 coded keys with the vehicle? If so, try the other coded key.
It will not start if the key is incorrect or if the code is lost/changed.
Old Sep 28, 2015 | 09:54 AM
yes I did try the other key and I also had a locksmith program two more keys for it. ANy other ideas what could be the cause?
Old Sep 28, 2015 | 06:52 PM
Can you check with your locksmith to see if he had the scan tool that would determine if the Passive Anti-Theft System (PATS) was functioning (enabled). The PCM controls the functionality of the PATS if it gets the proper info from the key and the system.
JMan525
Oct 20, 2017 08:53 PM
blaisa
Jul 16, 2015 01:18 PM
makuloco2000
Oct 3, 2014 02:14 PM
primem
Dec 17, 2013 12:24 PM
max powers
Mar 21, 2008 06:14 AM
