still no power to fuel pump
Cool , glad to hear you got it going , also their bad about having a problem with the connecter plug going to the top of the tank ,
see quite a few that the plug has melted from excessive heat from a bad connection, usually you can get away with just cleaning up the connecter an squezzing them a little tighter ,also on the ground side of the plug Ive found loose that will give you a intermitt start .
make sure you use some di-electric grease on the terminals
jozepy24
Jul 13, 2019 05:21 AM
fordexpedition2006
Apr 21, 2017 05:23 PM
ryche
Feb 27, 2015 01:35 AM
daveranger
Aug 10, 2007 08:51 AM
