1989 T-bird AOD transmission
Old Jul 11, 2019 | 07:28 PM
gironha's Avatar
Question 1989 T-bird AOD transmission
So I have the tranny out of the car. Changing the front and rear seal and the dipstick tube seal.
My question is, Is there anything else I really should replace while I have it out?
Old Jul 11, 2019 | 09:02 PM
You are going to change the fluid and filter Yes/no ?
Old Jul 11, 2019 | 11:18 PM
gironha's Avatar
That's already done. But the tranny doesn't need to be out of the car for that. I was thinking more of things that can only be done (or are a lot easier) if the tranny is out.
Old Jul 12, 2019 | 11:35 AM
This is s known good trans, in your driven vehicle? Or a fresh install?
Old Jul 13, 2019 | 09:51 PM
gironha's Avatar
It is known good. Was just leaking. Small leak but I got tired of the drip, drip, drip.
Old Jul 13, 2019 | 11:26 PM
gironha's Avatar
So what is right torque on the pan bolts? Is it 5 or 7 ft/lbs ?
Old Jul 14, 2019 | 09:01 AM
The shift governor used to like to come loose on the AOD, but if was normal ops, no need for inspection.
10lbs is good..
Old Aug 5, 2019 | 02:31 AM
gironha's Avatar
When changing the rear seal I notice the trans output shaft moves laterally about 1/8 inch. Is that normal? I am thinking it shouldn't be moving at all.
grumpyone
Oct 21, 2019 07:44 AM
Mando13#
Apr 7, 2019 10:43 PM
loudlarry
Mar 3, 2011 04:44 PM
wannabegreasemonkey
May 16, 2009 08:37 PM
demond96
Oct 26, 2005 12:00 AM
