94 t bird 4.6 runs rough when I plug in the map
Old Nov 26, 2019 | 12:24 PM
208ford's Avatar
Default 94 t bird 4.6 runs rough when I plug in the map
hello I just recently got a 94 ford t bird. I am new to the car and I haven't had any luck on diagnosing the problem. the car runs great with the map not plugged in but when I plug it in it will idle but I cant touch the throttle. the car isn't throwing any codes so idk were to start.
Old Nov 26, 2019 | 05:04 PM
Ford MAP sensors generate a frequency that the computer monitors. If it is malfunctioning or out of range performance is affected.
Usually when performance improves when we unplug that sensor it is because the ECM substitutes a fixed figure so the vehicle can be driven to a repair facility..
Old Nov 26, 2019 | 05:13 PM
208ford's Avatar
so your thinking the map sensor is bad is there any way to test it without throwing money at it.
Old Nov 26, 2019 | 05:24 PM
You would need a meter that reads frequency and most folks don't have one . Those sensors are not that expensive, but it would be prudent on your part to have a shop check and verify that it is malfunctioning.
Old Nov 26, 2019 | 05:26 PM
208ford's Avatar
I don't have those there 120 here. and shop rates here are high. I'm very mechanically inclined just never dealt with this issue so its new to me.
Old Nov 26, 2019 | 05:35 PM
Tell us how you decided to take the MAP sensor out of the system.
Old Nov 26, 2019 | 05:38 PM
208ford's Avatar
it was already unplugged when I got the car. my grandfather bought it at a auction and ended up not wanting to deal with it and gave it to me. I had to replace the drivers door hing the headlights the hood and the panel they were mounted to also the exhaust donuts.
Old Nov 26, 2019 | 05:48 PM
Ya got me there !
Shop around an get some estimates. Not all places charge the same amount for parts.
Sippy
Mar 21, 2017 09:46 PM
Josh Sanders
Jan 31, 2013 04:19 PM
darylsr
Jul 8, 2008 10:59 AM
jonrock
Oct 6, 2007 06:07 PM
ajsvforce
Dec 30, 2006 01:38 AM
