Carb Question
Old Feb 8, 2009 | 01:11 PM
donnasbird's Avatar
Default Carb Question
I have a 1968 390 FE truck motor with a Ford intake # D5TE9425MB. My carb is an Autolite # C7AF AH. Can these be combined with the proper spacer, and which spacer do I use. The motor had a two bbl. intake originally, but I wanted to go to a 4bbl. I plan on putting it in a 66 T'bird.
Old Feb 8, 2009 | 10:43 PM
That manifold should have an EGR passage between the carb mounting studs on the right side.. If so, you'd have to make sure the aftermarket spacer plate would contour and cap the EGR passage, or, 'plug and surface' the EGR passage and use a straight 4 hole plate spacer.. The plate thickness would have been about 1" ..
Old Feb 11, 2009 | 09:35 AM
donnasbird's Avatar
Thanks;
Do you recommend welding? This manifold seems cast. I'm wondering if a tight fit plug and some JBweld would hold up to manifold vacuum. Am I better off trying to find a different manifold?
Old Feb 11, 2009 | 10:22 AM
No welding needed..
It is cast iron..
If you clean the EGR passage out you can just press a solid steel plug into the passage level with the deck or just slightly above ,and then finish it to the carb/deck height.. Or you could thread and plug the hole.. That passage is exhaust feed, so it won't be a vacuum issue, although you want a decent press fit.. If you have any problems with that manifild I have the exact manifold here from days gone by.. FREE.. if you pay the shipping cost
Old Feb 17, 2009 | 02:59 AM
goinstrong's Avatar
wow. A '68 motor with a '75 intake and a '67 carb. in a '66 car. That about takes the cake. Welding cast is a bit of he**. It can be done if you're decent at welding and have a MIG welder that's any good, but I'd sure stick to the JB idea - carefully rough some edges in for the JB plug to grip (dremel tool) and it should hold up better.
waynesford
Jun 27, 2012 11:21 PM
outlander330
Apr 1, 2012 10:07 PM
mbgt
Aug 24, 2007 04:13 PM
miamipammy
May 27, 2007 04:40 AM
hicracer
Jan 27, 2005 03:31 PM
