05 PSD lower radiator hose clamp failure
Old Dec 8, 2008 | 10:08 PM
Treeclimber's Avatar
Default 05 PSD lower radiator hose clamp failure
My 05 powerstroke diesel lower radiator hose clamp failed. Doing some Google searching, I found this site, but can't quite figure out how to do an actual site search to see if anyone else has posted this problem.
What I'm wondering, is this a Ford TSB; if so, will Ford fix it for free? I've looked in the TSB but there's dozens of bullitins relating to the 6.0 cooling system, but the TSBs don't go into a lot of specifics on what is / was covered.
Thanks in advance
Treeclimber
Old Dec 9, 2008 | 12:39 AM
Default RE: 05 PSD lower radiator hose clamp failure
The spring clamps failures were an 'issue' for the earlier build 6.0s and would snap in two, sometimes leaving a half portion of the clamp, orwould be completely gone.. The later builds didn't see a lot of clamp failures (spring clamps have been around a long time) but always a failure possibility, and was more of a batch problem I believe.. The repair was to replace the broken clamp with a worm drive radiator clamp (so not to have to drain down the coolant, or create more labor time) and/or to sometimes double clamp the hoses depending on the clamp/hose location, like the upper most clamp on the lower hose.. Most techs would cut the old clamp off, but sometimes they were left with the addition of the worm clamp... There was a service message, but I don't see it listed...
Old Dec 11, 2008 | 07:10 PM
techford's Avatar
Hi, I agree with Hayapower. And I've seen not only Power stroke with that problem. If there is a TSB or SSM (Special Service Message) it will only be covered by your base warranty, this is not like a recall.
Nic.
eggs700
Mar 17, 2014 11:21 AM
88TBirdTurbo
Jun 17, 2013 09:41 AM
Alut
Jul 20, 2012 06:20 AM
rsbobcatservice
Feb 9, 2011 08:29 PM
hitandrun83
Nov 23, 2008 08:05 PM
