1949 Ford Custom Brake Lights Not working!!
Old Dec 2, 2013 | 04:37 PM
  #11
I'm a little concerned at this point.
Does that vehicle have the battery positive cable running to the sheet metal or engine?
What I'm asking is; does the positive side of the battery go to an insulated terminal or does it go to the sheet metal ? Don't remember if they had a positive ground system.
Old Dec 4, 2013 | 01:31 PM
  #12
grindman's Avatar
I bet they did. Hello Hanky
Old Dec 4, 2013 | 02:28 PM
  #13
Hello Mr. Grindman !
Missed your good advice and humor. Welcome home!
Old Dec 5, 2013 | 09:35 PM
  #14
grindman's Avatar
I ain't went nowhere just ain't been on this sight for a while is all just been trying to make ends meet since I stopped working.
Old Dec 5, 2013 | 11:37 PM
  #15
Rusty Baker's Avatar
It gets hard as we get older. I had a 49 and I don't remember either.
Old Dec 6, 2013 | 07:03 AM
  #16
One thing I do remember about the 49 was that was the first year for that new body style. When trying to back it up in a tight driveway I kept steering it into the fence. The rear fenders had a curve in them and if I used the end of the fender as a guide it kept going into the fence. That's probably why I don't remember if it had a positive ground system. This isn't helping jonnny though !
Old Dec 6, 2013 | 09:20 AM
  #17
askforjonny's Avatar
Exclamation Yes! Hahaha
The 49 is a positive ground 6volt system unless it has been converted over to 12
In the following week or so i will be over on the east side to put a little work in.
First I'm going to throw an inline fuse from the battery ( neg side. )
- if I have brake lights then I will open up the original loom and start the trace.
I see a Custer of these damn rubber covered wire fuses.
Honestly I'm assuming it is one of them causing the problem...
Because they are a pain in my existence I was thinking about just rewriting the whole thing. (Meaning dash and engine)
Putting a new style fuse box way up under the dash somewhere.
I will let you know what the out come is and eventually throw some pics up on here...
The hard thing to decide in this situation is to loose the AWESOME ORIGINAL look and put modern wire and fuses or just look for a stock replacement harness for the engine and dash.... ( I chalk it up to 1st world problems)
Thanks.
Old Dec 6, 2013 | 12:22 PM
  #18
I believe you are on the right track by seeing if you can get everything working first.
Then after that, depending on what you find, will help in making your final decision regarding replacing all or some of the wiring. I'm sure you will keep in mind that 6 volt systems required heavier gauge wire than our typical 12 volt systems. Looking forward to some pix when you get the time.
Old Dec 8, 2013 | 02:45 PM
  #19
Default Its Photo TIIIIMMMMEEEE
It's Sunday and I have time to not post pics .....but here we go!
Old Dec 8, 2013 | 03:52 PM
  #20
Thanks, nice pix !
Sure brings back some memories. Keep us updated on your progress.
