1989 F-250 460 dies after warming up
Old Dec 14, 2024 | 05:27 PM
  #11
N460's Avatar
13.5 while running
11.5 while cranking at the high pressure pump
And it won’t start .
i changed the fuel filter today .
Old Dec 14, 2024 | 06:55 PM
  #12
N460's Avatar
Other observations :
if I feather the gas pedal just right I can prevent it from stalling while idling .
if I force the fuel pump to run by jumping it at the relay the pressure is at 40 psi with the engine off
with the engine running 32 psi at the rail perhaps a little low ?
I noticed the fuel return supply line on the rail has a kink in it . Perhaps restricting flow ?
Old Dec 14, 2024 | 08:28 PM
  #13
I am trying to come up with checks you can see right away.what you have or don't have.
Can you do this, when it will not start, and you cranked it some, remove a spark plug and see if it is wet with fuel or dry. . If wet, no spark. If dry no fuel. Then we have some idea of where to go next.
Old Dec 14, 2024 | 10:23 PM
  #14
N460's Avatar
I will give the spark plug deal a try .
not sure what the diagnostic plug looks like .
Old Dec 15, 2024 | 08:08 AM
  #15
Just type in 1989 Ford diagnostic plug, and there are pictures and explanations of how to use it for diagnosis..
WadeFordman
Sep 22, 2023 04:20 AM
Robert Rhea
Aug 15, 2016 09:01 AM
soakem
Apr 12, 2014 04:18 PM
ChristineWV
Jul 27, 2011 07:16 PM
boat73
Sep 17, 2010 11:02 AM
