2015 Ford Edge Key Fob
Old Dec 23, 2024 | 02:03 PM
2015FordEdge's Avatar
Default 2015 Ford Edge Key Fob
I lost one of my two, 5 button, key fobs. I purchased a replacement through Amazon and need instructions on how to program it. Nobody in my area wants to do it without charging me $300+. Any suggestions would be appreciated.
Ray
Old Dec 24, 2024 | 12:27 PM
You might try this:
1.) Get in vehicle & unlock the doors
2.) Turn ignition on/off 8 times, & end with key position
being "On".
3.) Door locks should cycle
4.) Press any button on the remote
5.) Turn ignition off & remove key
6.) Test remote
Old Dec 25, 2024 | 01:22 PM
Default 2015 Key Fob Programming
The suggested solution did not work
Questions:
After performing item one, does the door remain open or closed?
After turning the ignition on/off eight times, do I turn the ignition back for the 9th time or leave it on after the 8th time?
Item 5 - there is no key to remove as my 2015 Ford Edge Titanium has a push button start.
Should I leave my working fob out of the car during this process?
Thanks for the reply.
Last edited by 2015FordEdge; Dec 25, 2024 at 01:24 PM. Reason: Left out a question
Old Dec 25, 2024 | 04:15 PM
Does your owner's manual provide any helpful info regarding remote programming ?
Old Dec 26, 2024 | 12:28 PM
Default 2015 Ford Edge key fob
The manual states that you must have two working fobs before you can program another non working fob.
Old Dec 27, 2024 | 05:45 AM
The situation sounds similar to key programming and you might check with a local locksmith. They usually have the equip to do programming and usually charge less.
Worth a try.
Old Dec 30, 2024 | 11:03 AM
Thanks, I will check around. I will reply if I get this issue resolved.
AVAYKTM
Feb 17, 2023 11:30 AM
Kass
Nov 17, 2022 12:07 PM
Fillers
Nov 4, 2021 08:21 PM
mullal2000
Sep 12, 2021 05:57 PM
ford2018
Nov 3, 2018 01:17 PM
