1994 F-150 cutting out badly
Old Mar 26, 2011 | 06:53 PM
  #11
bdoll32's Avatar
I found out that it was way out of time. I set the timing and now it seems to be running way better. I can actually spin the tires in loose gravel and it will go into overdrive and stay there for the most part. But it has started to start really hard again. Once the truck has started once i can turn it off and it will start right back up. After it has sat awhile its really hard to start. If you guys have any suggestions to why it is doing this it would be greatly appreciated. thanks
Old Mar 27, 2011 | 03:38 AM
  #12
bdoll32
Just touching all the bases;
Remove the vacuum line from the fuel pressure regulator, does it show any gasoline coming out of it?
Old Mar 27, 2011 | 08:57 AM
  #13
bdoll32's Avatar
Do i take it off while its running?
Old Mar 28, 2011 | 04:15 AM
  #14
No, Shut the engine off then remove the vacuum line from the pressure regulator and watch to see if any gasoline comes out of the regulator assy. If it does ,replace it .
There should also be no gas in the vacuum line you removed to check.
paf150driver
Mar 28, 2009 01:25 PM
kal13
Mar 20, 2009 07:44 PM
jch2122
Sep 14, 2008 07:43 PM
93mod
Mar 13, 2006 07:18 PM
tallguy1877
Sep 15, 2005 07:58 PM
