2003 f150 supercrew overdrive not working PLEASE HELP
Old Aug 31, 2014 | 08:37 PM
Daniel048225's Avatar
Default 2003 f150 supercrew overdrive not working PLEASE HELP
I have a 2003 f150 supercrew with the 4.6 and the OD button is not working. I checked the fuse and everything was good. I also disassembled the column and inspected the wiring and everything looked good. The lights also work in auto mode with no problems. The last thing I done was checked continuity and had it on two wires coming from the overdrive button while holding the button in. I wish I could remember which color wires it was but I can't. I don't know if continuity is supposed to stay when I let off the button or not. But if someone could please give me some more guidance on this issue. Thanks a million.
Old Aug 9, 2017 | 06:02 PM
pwcx's Avatar
I have a 2002 Excursion 5.4L XLT. The shift lever was bad a I replaced it. The new shift lever has the overdrive off on all the time. I ordered a second and installed it and it is the same??? everything else works well.
Old Aug 10, 2017 | 07:37 AM
Power from a 5 amp fuse in the central junction box powers the OD Off switch and light. RD/Yel wire.
When the button is depressed to the off position that power is sent to the Powertrain control module , pin 29. TN/WH wire
The PCM then grounds the wh/lg wire to the light to make it lite. If that wh/lg wire is not grounded anywhere between the switch and pin 12 on the PCM there is a good possibility the problem is with the PCM.
Always a good move to check the plugs on the PCM for any corrosion.
fredastro
Nov 18, 2011 10:38 AM
DavidK7107
Jan 5, 2011 07:52 AM
T MONEY
Oct 10, 2010 05:51 PM
volksjr
Jan 22, 2010 02:52 PM
protocol0
Sep 9, 2005 05:26 PM
