2007 Ford Windstar popping noise in intake and stalling
Old May 28, 2013 | 12:23 PM
billpolkjr's Avatar
Default 2007 Ford Windstar popping noise in intake and stalling
I have a 2007 Ford Windstar with a 4.2l engine. It is making a popping noise in the intake manifold and it will shut down while driving like you turned the key off. I have replaced the air filter, the fuel filter, spark plugs and 1 coil. I have also cleaned the fuel injectors. If it matters, when I unplug the IAAC, it makes no change at idle. HELP, I am my wits end. Thank you in advance.
Old May 28, 2013 | 03:16 PM
bluewind's Avatar
Is the CEL on? what code?
Old May 28, 2013 | 03:27 PM
billpolkjr's Avatar
It was not on but there was an active code for a # 3 cylinder misfire
Old May 28, 2013 | 06:13 PM
How many miles on the vehicle Bill?
Old May 29, 2013 | 01:20 PM
billpolkjr's Avatar
It has 79000 miles on it (sorry for taking so long to reply).
Old May 29, 2013 | 01:33 PM
bluewind's Avatar
You said you changed one coil. I believe it has 1 coil pack with 6 towers for 6 wires. Get all new wires if you haven't yet.
Have you checked for vacuum leaks?
Did you check the IMRC linkage for missing bushings?
351w
Dec 22, 2014 03:45 AM
billpolkjr
May 30, 2013 09:47 AM
Higgy1982
Apr 26, 2007 01:34 AM
texasquail
Jan 29, 2007 12:17 AM
mad man
Jan 4, 2006 03:17 PM
