2015 Ford Focus SE - neither 12v cigarette lighters work (tried replacing fuse)
Old Sep 12, 2022 | 02:26 PM
cma2032's Avatar
Default 2015 Ford Focus SE - neither 12v cigarette lighters work (tried replacing fuse)
Neither the cigarette lighter next to the gear shift, or the one in the center console will power up. The fuse I pulled looks fine, but I tried replacing it anyway, which did not make any difference. I tested both outlets with a multimeter after I powered the car on, and got 0 V on both.
Is there anything else obvious I should try, short of somehow replacing the sockets? It seems there must be a root cause, since both are non-functional.
Old Sep 12, 2022 | 02:37 PM
Something you might try,
Verify with your meter, do you have power on both sides of the cigar lighter fuse, ?
Old Sep 12, 2022 | 02:38 PM
cma2032's Avatar
I did try replacing the fuse altogether, with no difference. Do you mean continuity in the slot where the fuse goes?
Old Sep 12, 2022 | 04:39 PM
We are trying to verify if power is available at the panel that supplies power through the fuse, does the key have to be on to get power there ?
Did you check if any fuses are in the engine compartment fuse panel?
dil98
May 31, 2021 11:00 PM
space
Oct 3, 2019 04:17 PM
DrKrappenSchitz
Aug 27, 2019 07:49 PM
BobinIL
Jun 15, 2017 01:31 PM
