2018 explorer driver seat motor
Old Jul 12, 2025 | 11:21 AM
thegr8fisherman's Avatar
Default 2018 explorer driver seat motor
My driver seat motor keeps running
Old Jul 12, 2025 | 08:40 PM
Get a capable scanner (Foxwell NT510 Elite) and check for possible DTCs, run active test on the module, and reset the module, if you can't borrow or can't afford to buy the scanner, you just can't DIY and find a mechanic to fix it.
The motor is controlled by the DSCM module, if the motor runs by itself all you can do is to get to it then clean and check the wiring for possible short to power, that's ALL you can do. And in the meantime just disconnect the connector. If you think the motor is bad and the DSCM is still good, then just replace the motor yourself.
Old Jul 13, 2025 | 07:17 AM
Don't overlook the possibility of the seat motor switch being the cause of the problem. .
If you have power at the sw coming in, there should be no power coming out of the sw to the motor in the off position.
JDH
Apr 24, 2022 10:09 AM
QQ
May 29, 2013 10:46 PM
unclebigg
Feb 23, 2012 12:20 PM
jfsprings
Mar 15, 2011 03:50 PM
p8ntballsniper87
Jul 2, 2009 02:35 PM
