2021-2023 Ford f-150 Tail light Wire Gauge?
Old Nov 1, 2023 | 08:44 PM
Redline1's Avatar
Default 2021-2023 Ford f-150 Tail light Wire Gauge?
Hello everyone, I’m looking to find what’s the wire gauge for 2021-2023 Ford F-150 LED tail lights. I need to replace one of the wire that got cut while doing a replacement upgrade to led but Im not sure what the wire gauges are.I tried it with wire gauge measuring tool i don’t believe it gave me an accurate measurement and I have found multiple different answers doing research online but nothing that seems correct.
thank you for your help in advance
Old Nov 1, 2023 | 09:01 PM
Without actually looking at the present wire, this is what I would suggest. Since you are going to need some wire to replace what might be damaged, take a ride to any auto supply store and ask to see 14, 16 or 18 gauge wire. What may be adequate for the present time with LEDs ,just maybe up the road something may get added and the wire for LEDs might not be sufficient to handle any addition. If you don't want to consider this , you most likely would be good with 14 gauge wire.
Sometimes the size fuse for the parking lamps will tell you the size wire they used.
dmowry
Aug 3, 2022 12:39 PM
RacingRoger
Apr 5, 2021 12:27 PM
1978F250
Apr 26, 2012 03:42 AM
smurph130
Apr 14, 2009 07:53 AM
ugbandtulsa
Feb 25, 2009 11:56 PM
