95 SHO Inconsistent Running
Old May 23, 2007 | 10:05 AM
TerryBass's Avatar
Default 95 SHO Inconsistent Running
Hi, all. Thanks for this forum. I have a 95 SHO Taurus with an automatic. Lately, while running it has a slight loping to it. I pulled all the injectors and had them tested and cleaned. No difference. The car also has a starting issue. After I stop the motor and restart it within about 15 minutes, sometimes it just cranks. If I turn it back off and try again, sometimes it will start, but now the tachometer doesn't work. While driving, the tach will suddenly come back to life. All the while, I will have the engine light come on intermittently. When I put my code checker to it, it can't give me any readings because it can't even do the "number of cylinders" check. Any ideas? Is this the symptoms of a crank position sensor starting to go bad? Thanks.
Spoofy
Dec 27, 2008 01:07 AM
96F350Panel
Nov 27, 2007 02:59 PM
Pike002
Aug 7, 2005 07:29 AM
mudjnky
Aug 3, 2004 11:25 PM
1BrokenSHO
May 9, 2004 01:45 AM
