96 escort oil pan
Old Mar 4, 2012 | 01:19 PM
995jim's Avatar
Default 96 escort oil pan
Hi, can i remove the oil pan on a 1.9ltr with motor in vehicle? If so are there any tricks or is it like an old school v8. If i cant remove in place where do i start. I need to investigate the #4 rod assy. thanks jim
Old Mar 4, 2012 | 02:32 PM
greasemark's Avatar
Yes, these pans are very easily removed after the catalytic convertor is removed. I'll save you the trouble though; usually (not always), but usually, you're pulling the engine if you have a noise. This was a common death for these engines.
Old Mar 4, 2012 | 02:40 PM
995jim's Avatar
In an engine removal, other than trans bolts,, engine mount at top, wiring, can I extract that engine with the cherry picker. thanks jim
Old Mar 5, 2012 | 08:28 PM
greasemark's Avatar
Yes, just bring it forward the couple of inches, and you'll be fine. It's a very easy to extract engine.
jcasaccio
Oct 7, 2018 08:02 AM
kpl1228
Apr 2, 2013 06:42 PM
tony tiger 54
Apr 30, 2011 02:53 PM
carlzt
Jan 11, 2009 02:07 AM
pterns
Oct 8, 2005 01:44 PM
