AC vents ... To lube or, not to lube ??
Old Aug 8, 2024 | 02:53 PM
Rich73Kelly's Avatar
Question AC vents ... To lube or, not to lube ??
Kind of an off-the-wall situation on our '07 Freestyle Limited ...
The adjuster slides on the dash heat/AC vents are hard to move back and forth freely. They move but, not easy enough while driving that the whole vent moves. I thought about like, PB Blaster or WD40 but, don't want to smell it on a daily basis. My next thought was to give them a small shot of silicone spray but, am concerned with the chemical reaction with the plastic. Or would it be more appropriate to just rub a bit of White Lithium grease on the affected areas?
Old Aug 8, 2024 | 03:31 PM
I know NAPA sells spray cans of lubricating grease. Can you check if the "fragrance" is offensive to you ?
There are other products you can try, , what about spray SPAM which is used in food prep ?
Old Aug 10, 2024 | 10:02 PM
Try WD-40 Dry Lube, no odor, no mess, no residue.
Craigb
May 31, 2023 02:45 PM
nick117
Sep 29, 2018 02:03 AM
lilblue
Jun 13, 2008 11:25 PM
tennford
Oct 9, 2007 07:36 AM
funkdoobiest
Sep 4, 2006 02:33 AM
