Car throttle body closing at WOT and backfire
Old Mar 10, 2023 | 11:54 AM
  #11
sarxworks's Avatar
Originally Posted by raski
If you increased your engine's rpm and held it there, the vacuum will quickly drop some and go right back up. It sounds like your exhaust is clear.
I do not think you have a misfire. If that happened long enough, a code would be set . A misfire on a four banger would result in a very rough, shuddering engine.
I would be curious as to what your fuel trims are at to actually see how the engine is performing.
Also you might want to test your air pump's check valve. They can cause a backfire when you back off the throttle.
https://www.rockauto.com/en/moreinfo...vmMfS8ANlMpp8g
Okay did the intake vaccum test again and got the same result. Based on it, it doesn't seem like I have a clogged converter
Test:
https://imgur.com/a/J0QQMqR
Here are all my fuel trims:
https://imgur.com/a/PpNEKtU
Nothing in particular is out of the ordinary there, the trims just flucate between +- 4-5% and is pretty steady.
Where exactly is my air pump located?
Old Mar 10, 2023 | 12:08 PM
  #12
sarxworks's Avatar
When you changed the spark plugs did you do one at a time or all at once?
Air coming from the AIR pump usually goes to the exhaust manifold only or is diverted out of the system. Should not be noticed or felt at the intake or throttle body, but anything is possible until we determine why you are feeling puffs at the throttle body AND the exhaust. This engine does have a dual overhead cam system with a timing chain.
Variable valve timing could be involved here too. 76,000 mi is not a lot of miles, unless regular oil changes were not done to which the VVT system becomes susceptible to excessive wear and clogging problems.which may or may not throw any codes.
When I changed the plugs, I did all of them. When I got the car it was at 57k and apparently was sitting dormant somewhere for about a few years based on the expired emissions sticker when looking through carfax at first I see the car got its routine tune ups but it kept going back for electrical problems? (Not sure if it's the cigarette lighter fuse that keeps blowing or because of the alternator since I had to change it when first getting the car.
Old Mar 10, 2023 | 12:14 PM
  #13
sarxworks's Avatar
Also you may have noticed I didn't send the puffing noise...that's because it's not even happening now lol. All I did today was pull the plugs to recheck the vaccum (which came back the same and check the spark (what was also normal)
And the car ran fine at WOT. It's super inconsistent
One other thing I forgot to mention is that along
with the fuel pump, ford mentioned was that my fuel feed line had pinhole leaks in them? I didn't change that as I only went by what my local mechanic said who didn't say anything about it and just said my fuel pump needed to be changed.
Like here's the invoice of its any help:
https://imgur.com/a/IFILkB8
Old Mar 10, 2023 | 12:30 PM
  #14
Why I asked about replacing the plugs all at the same time or one at a time is MANY times guys get wires crossed and be it either coils or plug wires , either of which can produce what you were seeing.
Glad all is well , thanks for the update.
93fordbronco
Feb 12, 2018 04:46 AM
mbozant
Jun 27, 2014 10:08 AM
gk4949
Aug 24, 2010 07:27 AM
jineson23
Oct 27, 2008 03:41 PM
drw0392
May 25, 2006 02:50 AM
