Changed throtte body car wont drive forward now
Old Jan 26, 2018 | 08:09 AM
Aceboog's Avatar
Default Changed throtte body car wont drive forward now
I have a 2009 mercury milan having throttle body issues. It was going in limp home mode. Now that i replaced it, it wont go into drive.
Old Jan 26, 2018 | 10:56 AM
You might try removing the negative battery cable from the negative post and holding the removed terminal against the positive cable end for a few minutes to allow the memory to go away. Try that and see if that takes care of it. Also, make sure you didn't overlook reconnecting everything you removed.
Old Jan 27, 2018 | 12:15 PM
Aceboog's Avatar
i did that and it still wont do anything. Its weird because it had the throttle body problem so i changed it and it drove home. The next day it doesn't want to move forward. Could it be the maf sensor?
Old Jan 27, 2018 | 01:45 PM
Without being there , I do not believe the MAF sensor alone would cause a no trans engagement problem. If you rechecked all your work for any connections that may have opened, the next thing would be to check all the fuses. What about the plugs going to the trans? Will it move in reverse? Are all forward ranges inoperative? Is the shift lever moving everything as it should?
Old Jan 27, 2018 | 01:48 PM
Aceboog's Avatar
i didn't check plugs going into the transmission which side are they on? And what fuses should i check? It works in reverse but in drive it'll inch forward and thats it
Old Jan 27, 2018 | 02:17 PM
What we are trying to cover is the area where you worked when replacing the throttle body. If all is good, there could be a problem within the trans itself since reverse is operative. Don't like to speculate, but could be a problem with fwd clutch in trans.
Old Jan 27, 2018 | 02:28 PM
Aceboog's Avatar
The only reason i dont think its the tranny is because it went into limp home mode, i changed the throttle body, it wouldn't drive forward and then it started driving normal and the wrench light went out. But the next day its back to no forward. But no mil or codes thrown
Old Jan 27, 2018 | 04:41 PM
Without going off the deep end, do you think there could be a similar problem with the replacement throttle body? It won't be the first time. Where did you get the replacement? After being burned so many times with aftermarket parts I have learned to suspect everything.
Old Jan 27, 2018 | 04:58 PM
Aceboog's Avatar
I got the replacement off of rock auto it could be the problem. At this point i kind of hope it is
Ford4x4Fan#1
May 30, 2012 09:09 PM
BoostedE21
Oct 21, 2011 08:01 PM
Rogerseric
Aug 12, 2011 12:34 PM
goatpimp
Mar 28, 2010 11:28 AM
mws0019
Aug 7, 2009 01:18 AM
