cooling problem
Old Sep 20, 2005 | 11:06 AM
anthonyspeltz's Avatar
Default cooling problem
i ran cleaner though my f150 toclean the cooling system. It said to drive the truck for 8 hours with the cleaner and water in the system. I ran it longer than that and it started to overheat on me while sitting in traffic. When i checked the resivior it was bone dry. It has did this one other time with antifreeze in it this summer, but i only drive the truck on the weekends, could this be a head gasket craked block or what else could be the problem and is there anyway of troubleshooting this myself?
Old Sep 20, 2005 | 02:26 PM
techmanbd's Avatar
Default RE: cooling problem
Check your oil dipstick, see if it looks like water is in the oil or antifreeze, if so then you have a blown headgasket
Old Sep 20, 2005 | 04:18 PM
cctxfish's Avatar
Try useing a cooling system pressure tester to find leak and problem.
Old Sep 25, 2005 | 06:22 PM
hockeyhitman69's Avatar
or you could put a dye in your coolant and then get it checked with a black light
shagwagon
Apr 21, 2007 03:57 AM
F250B
Dec 16, 2006 01:33 AM
bigcars
Nov 16, 2006 12:01 PM
pmkls1
Sep 11, 2006 02:18 PM
bernieb
Aug 29, 2006 09:29 PM
