engine stumbels
Old Nov 16, 2006 | 03:32 PM
supersix's Avatar
Default engine stumbels
i have a 5.0 liter engine in a 88 lincoln town car . some times when i start the car and its idiling the rpms jump all over but the engine does not rev up or stall. and when i drive it stumbels when the engine is under load but ounce up to cruise it seems fine .but if the rpms start to jump it will stumbel. could this be the tfi ignition modual and if so how do i check it and replace. any help would be appreciated.
Old Nov 16, 2006 | 09:29 PM
masterexploder's Avatar
Default RE: engine stumbels
it sounds like it may be an egr problem, the egr is only ment to come on durring cruise, and it it is stuck a little open, it will choke the car and make it do what you are talking about. check the vacume line going to it, it may be leaking, or have no vaccum at all.
Old Nov 17, 2006 | 02:19 AM
wheelsup68's Avatar
really sounds like a vacum leak problem. Check all visible vaum lines for cracking and replace as necessary.
amcole82
Feb 11, 2011 08:18 AM
jamesmanning
Nov 3, 2010 10:49 AM
Bill in Tampa
Apr 27, 2008 09:30 PM
bmwrocks03
Apr 21, 2008 09:29 PM
daveranger
May 24, 2007 12:56 PM
