fast idle, '92 Ranger, 2.3L
Old Jan 8, 2009 | 08:52 PM
creativity's Avatar
Default fast idle, '92 Ranger, 2.3L
My truck's idle speed is high. I don't have a tach so I'll take a guess that the RPM's are roughly 3000. I unplugged the idle air bypass valve solenoid and idle speed drops to around 600. The problem was not fixed by substitution of the idle air bypass valve.
Help will be greatly appreciated.
Have a great day
Old Jan 8, 2009 | 09:12 PM
fblevins1's Avatar
Default RE: fast idle, '92 Ranger, 2.3L
Very strange indeed, I would have put money on the IAC after you disconnected it and the Idle speed dropped. So I wonder if you have a single injector throttle body? Take a look around that air intake valve (Not sure if they still call it a Butterfly) and see if it is not stuck closed or partially inoperative..etc.....
In the mean time if disconnecting it gets you 600 RPM, maybe you can run that way until you get it figured out.
Time to break out the Carb/Injector spray and really clean things up around your Throttle Body assy.
Joe Feds
Dec 19, 2007 12:45 PM
rmowry
Mar 30, 2007 12:33 AM
shoes
Mar 4, 2007 05:15 PM
moford
Dec 3, 2005 01:45 PM
bingermann
Nov 11, 2005 01:47 PM
