ford edge gets stuck in park
Old Jul 13, 2010 | 04:29 PM
pnthr1505k's Avatar
Default ford edge gets stuck in park
2010 ford edge will get stuck in park, has been in the shop multiple times and continues to happen.....any suggestions????
Old Jul 13, 2010 | 08:36 PM
Ford uses a solenoid to keep the vehicle from coming out of park to prevent jumping into reverse accidentally. To get this solenoid to release you need to step on the brake pedal and hold it down to get the vehicle out of park. Are you doing this? hanky
Old Nov 19, 2011 | 04:02 PM
eston's Avatar
Question 2010 ford edge gets stuck in park
has been in shop 3 times; gear shifter replaced...still intermittently would get stuck in park position...when this occurs ....aws light comes on control panel and no brake light...took in this week had steering colum swith assemblies --stop light replaced...today the problem occurred 8 times.
would appreciate any help.
thanks
eston
Old Nov 19, 2011 | 04:55 PM
greasemark's Avatar
So, if I'm getting this correctly, there are no brake lights when this happens? If so, that's the problem. If the shifter has been replaced, there is most likely a problem with the brake light switch, which needs to energize the brake lights to disengage the shift interlock. Fixing the lights will fix this. I would start with looking at the fuse to the lights for proper fit. Make sure it doesn't fall out or isn't blown. Also, check for loose connectors.
This is one of these problems that the dealer really shouldn't have a whole lot of problem fixing, as they would need to see it happen. But, since this is happening this often, it shouldn't be a problem.
Old Nov 19, 2011 | 11:10 PM
eston's Avatar
Default greasemark
thanks; i will have my husband check it out tomorrow...
Old Nov 20, 2011 | 07:17 PM
greasemark's Avatar
Reminds me of what my mother used to say to me or my father whenever something mechanical would break: "Mark or Ed, fix it!"
The joys of being married or having raised a mechanic...
Econoline150
Jun 26, 2014 09:56 AM
Greg Weiss
Sep 1, 2013 05:58 PM
mfurtney
Nov 18, 2012 10:37 AM
mfurtney
Nov 18, 2012 10:05 AM
sistreat
Mar 4, 2007 09:49 AM
