Ford ranger cab swap
Old May 17, 2024 | 06:14 PM
Mikeawells's Avatar
Default Ford ranger cab swap
I bought a rolled, 2003 ford ranger 4x4 4.0 liter and swapped the cab out with a 2000 2 wheel drive that had a 3.0 motor. Now it won’t start, the anti theft light is blinking and when it turns over it blows the anti theft fuse. Any ideas? Will I need to change everything out inside the dash to get it to match up?
Old May 18, 2024 | 06:45 AM
First you need to find out why the fuse is blowing. Suggest you recheck all your work for a wire that may be pinched and grounded resulting in a shorted circuit.
The blinking anti-theft lamp suggests a problem with the security system. Could be the key, computer programming or both. If the computers were changed you might require the computer to be programmed to the vehicle. A capable ,certified locksmith can usually handle this. Check around and see if you can find one in your area..
tjship76
Feb 18, 2012 11:56 AM
kmoninge
Mar 13, 2008 09:38 AM
tlteasley
Nov 4, 2007 12:45 PM
Hbombmike
Apr 20, 2007 02:31 AM
treetopp87
Aug 18, 2006 12:27 PM
