Frustrated with my F150
Old Jun 28, 2005 | 01:29 AM
joejohnb's Avatar
Default Frustrated with my F150
My 1990 F150 Supercab LongBed 4x4 5.0L has been parked for almost a year now. I replaced the transmission with a brand new one from www.rebuilt-manual-transmissions.com, but that is not the problem. My truck started almost instantly after replacing the trans. I left it running for at least 30 minutes to keep the charge in the battery, but the truck just died out. Since then, I've tried everything from, new ignintion module, new stator & electronic module, and replaced the fuse relay's. My truck cranks it just doesn't want to start. It did at first, up until i changed the stator. Here's the other thing. I marked the #1 distributor location before changing the stator, and for some reason both Chilton's and Hayne's Truck manuals have no picture for me to see where the #1 marking is on the distributor area between the two heads. I was able to find TDC on the harmonic balancer, but can't get the distributor aligned or TDC. Maybe I missed something, but I am starting to lose all hope already. PLEASE HELP! I love my truck, but I get frustrated every time I work on it and no luck.
Old Jun 28, 2005 | 02:04 PM
cctxfish's Avatar
Default RE: Frustrated with my F150
The oil pump is driven off the dist. so you probably had the dist. lined up just not seated all the way. Just turn the engine about 1/4 turn to make the dist. fall in to place. good luck
clarep
Jan 16, 2014 04:55 AM
bkasprowicz
Aug 10, 2010 08:50 PM
onem2f
Jul 13, 2010 05:25 PM
Jayrome03CVPI
Feb 8, 2009 10:04 AM
llamababy
Mar 14, 2007 02:27 PM
