I could use some brake advice F350
Old Oct 26, 2010 | 12:36 PM
chad91f350's Avatar
Default I could use some brake advice F350
I have replaced MOST of my brake components Master cylinder Brakebooster Wheel cylinders pads and shoes spring and self adjuster kits. I have bench bleed master cyl. bleed all lines cheaked for leaks found non. When the truck is on and i press the brake it loses presure till on the floor.Any ideas?
Old Oct 26, 2010 | 04:30 PM
You didn't give the year of your truck , therefore we don't know if an anti-lock system is involved.
Some things you might check;
Did you adjust the self adjusters as close as possible before putting the drums back on?
Did you bleed the brakes in the correct order, RR,LR,RF,LF?
Of course when bleeding , you kept the master cyl full so it couldn't draw in any air?
Usually when you lose pressure as you describe, either you have a leak somwhere or there is air in the system or the master cyl is questionable. Let us know what you find.
Old Oct 30, 2010 | 02:12 PM
351pinto's Avatar
yes and its always a good idea to bleed master cylinder be hooking up the lines to it
BigBlack302
Jul 8, 2012 01:05 PM
ranger gsi
Oct 2, 2009 11:13 AM
BrownVicdude
Nov 27, 2007 07:34 AM
stobs5@rogers.com
Apr 4, 2006 07:41 PM
