Intalling a Torque Converter
Old Mar 26, 2011 | 08:29 AM
Ford1st's Avatar
Default Intalling a Torque Converter
I'm trying to install a Torque Converter in a 2001 Ford Exploer, I cannot seem to get it to seat all the way, Looking for suggestions or tricks of the trade
Old Mar 26, 2011 | 03:13 PM
First , is this a replacement torque converter?
Second , if so , were you able to compare the one removed to the replacement?
If you did and they were exactly the same, there are two slots in the converter hub that have to index with the two lugs in the front pump gear. If you have the converter out and look in the front of the trans you should be able to see the lugs on the pump gear.Hopefully you didn't force anything because that could complicate things.
When the slots are properly indexed to the gear the converter will slide in and you can feel it bottom out. That's all there is to it.
rosebud12
Mar 30, 2010 07:24 PM
whitall
Jul 20, 2007 11:54 AM
railboy36
Jul 16, 2007 06:39 PM
railboy36
gearyoil
Apr 1, 2007 09:35 PM
