low clutch pedal
Old Aug 24, 2007 | 02:27 PM
groho's Avatar
Default low clutch pedal
brand new to this particular forum. gotta '96 explorer 4WD, 5 sp., brand new clutch, resurf'd flywheel, pressure plate, master cyl, etc, etc. probably less then 1K miles on it. the release/engagement point of the clutch is very very low on the pedal. i agree with this forum that there's probably an air pocket somewhere. also agree that these buggers are a pain to bleed andget all the air out. Anyone have any little secrets they want to share, getting all the air outa this system. I saw one note, running a line from the slave up to the reservoir and bleed the sys the same way you would prime a master cyl. Any other ideas?
BTW, bleed ford blue. . . . F250 PSD 4WD CC, Ford Exploder, and '66 Ford Mustang.
Old Aug 25, 2007 | 08:59 PM
groho's Avatar
Default RE: low clutch pedal
i re-bled the system again yesterday using the line trick between the trans and resevoir and seems to have gotten the air pocket out of the master cyl. I spoke to the shop who did my clutch, and they are aware of the headaches this system causes. The angle of the master causes air to get trapped.
ranchhorse
Sep 4, 2015 02:06 PM
barkfarm
Jan 26, 2012 06:00 PM
cyberrkatz
Jul 7, 2010 09:46 PM
skid2964
Sep 27, 2009 02:29 PM
machesked
Jun 5, 2006 12:04 PM
